WK 2005+ servisny manual tutok :
http://www.jeepforum.cz/showthread.php?tid=571
treba byt zaregistrovany, trva to necelu minutu, mailiky chodia okamzite
112MB zip, 150MB rozbaleny PDF subor. Teraz sa silnejsie chytte stolika :
7203 stran. SEDEM TISIC.
Tomu sa povie manualik. Rovnako ako Chrysler, v tomto jedinom subore mas totalne vsetko o Jeep Cherokee. Absolutne totalne.
Strana 19 :
AXLE
NOTE: DaimlerChrysler recommends using MoparT lubricants or lubricants of equal quality
FRONT AXLE
² 200MM - MoparT Synthetic Gear Lubricant 75W-140
REAR AXLE
² 213MM - MoparT Synthetic Gear Lubricant 75W-140
NOTE: Vari-lokT equipped axles require 118 ml (4 ounces) of Limited Slip Additive be added to the lubricant.
TRANSFER CASE
Recommended lubricant for the NV140 transfer case is MoparT ATF+4, Automatic Transmission Fluid. Recommended
lubricant for the NV245 transfer case is MoparT NV245/247 Transfer Case Fluid.
AUTOMATIC TRANSMISSION FLUID
NOTE: Refer to Service Procedures in this group for fluid level checking procedures.
Mopar ATF +4, Automatic Transmission Fluid is the recommended fluid for DaimlerChrysler automatic transmissions.
Dexron II fluid IS NOT recommended. Clutch chatter can result from the use of improper fluid.
Mopar ATF +4, Automatic Transmission Fluid when new is red in color. The ATF is dyed red so it can be identified
from other fluids used in the vehicle such as engine oil or antifreeze. The red color is not permanent and is not an
indicator of fluid condition. As the vehicle is driven, the ATF will begin to look darker in color and may eventually
become brown. This is normal. ATF+4 also has a unique odor that may change with age. Consequently, odor and
color cannot be used to indicate the fluid condition or the need for a fluid change.
MoparT v tom texte co som okopiroval je to sibnute americke Mopar(C), copyright atd. Proste pravnici. MoparT inak neexistuje, nic to nie je, proste je to len technicka kravina ako som okopiroval text z PDFkoveho manualu.
Mopar je obchodna znacka celeho koncernu kde v danom case patril Dodge, Chrysler, Jeep. Katalogove cisla a cisla dielov (Part Number) Moparu absolutne presne sedeli s katalovymi cislami / cislami dielov Mobil1 co sa tyka olejov. Verifikoval som ked sme zacali kupovat Chryslerov do rodiny.
Takze definitivne ATF+4. Uprimne, verim tomu ze Mercedesova norma 236.14 a Jeepova ATF+4 su sialene podobne - boli urcene pre najvykonnejsie masiny. Kedze som pisal o pouziti ATF+4 v servoriadeni Chrysleru (naozaj je to v servisnom manuali), pre Jeep WK je to takto :
POWER STEERING FLUID
This system requires the use of hydraulic system/power steering fluid which meets Daimler Chrysler specification
MS-10838, such as Mopar part number 05142893AA, or equivalent, DO NOT MIX POWER STEERING FLUID
TYPES. Damage may result to the power steering pump and system if any other fluid is used, and DO NOT OVERFILL.
Mal som dojem ze vzhladom na to ze ATF+4 v automate znasa neporovnatelne vacsie bomby nez olej v serve, ze sa moze pouzit aj do serva automatovy ATF+4. A tu mame potvrdenie :
http://www.moparrepairconnection.ca/che ... 5142893AA/
https://www.jeepforum.com/forum/f67/pow ... n-1754010/
Neskor bolo nahradene novym katalogovym cislom :
https://www.moparpartsoverstock.com/p/_ ... 631AA.html
Part Number: 68234631AA (05142893AA) a premenovane na Mopar Power Steering Fluid+4 [ano, to plus styri nieco evokuje ze]
https://www.pepboys.com/mopar-power-ste ... uct/846329
takze, ATF+4 je univerzalna tekutina pouzivana v tomto koncerne uprostred minulej dekady. Samozrejme nie do brzd, o tych sa nebavime.
Cheers !
