Vcds Chyba 0836
- Dátum registrácie: 13.10.2018 17:45 Zdieľať na Facebook
Vcds Chyba 0836
Dobrý den mam VW passat 2016 b8 2.0tdi 110kw motor crlb.Pri diagnostike cez VCDS mi stale vyhadzuje tuto chybu 0836-ROD.
Zmazal som ju uz asi 10 krat ale stale sa objavi skusam hladat aj na nete nieco o tom ale k nicomu sa neviem dopatrat.Acc mi funguje bez problemov nikdy ziaden problem auto pouzivam denne na dialnici asi tak 90 km denne Acc stale zpnute.
Ma niekto nejaku ideu ??? alebo skusenost ??? dakujem.
Vypis z VCDS:
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 3200674A51FFC428949C804D
Shop #: WSC 05311 115 00093
ASAM Dataset: EV_CACBOSCHVW48X 001008
ROD: N/A
VCID: 346084FF9F28C89E89-8060
No ASAM data for: "EV_CACBOSCHVW48X" (VW48)
1 Fault Found:
0836 - ROD - Unknown Error Code
- 00 [008]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 254
Reset counter: 94
Mileage: 161801 km
Vypis z VCDS:
ROD: N/A
1 Fault Found:
- 00 [008]
Freeze Frame:
Fault Priority: 6
Reset counter: 94
Mileage: 161801 km
- jaroslavelektro
