Audi A6 C7 MMI - navigacia
- Dátum registrácie: 30.01.2015 21:19 Zdieľať na Facebook
ahojte otazka na problem s navigaciou v AUDI A6 C7 2012 neukazuje spravne polohu auta,ukaze aj 50km od aktualnej,niekedy po restarte akaze spravnu ale po chvili,case znova...
vraj zla GPS antena ale Ta bola vymenena a nic sa nezmenilo...
aktualizovat mapy?
software?
alebo poradte
dakujem
aktualizovat mapy?
software?
alebo poradte
dakujem
V podstate budeš potrebovať na diagnostiku,aj navigácia sa diagnostikuje,ja mám len ročník po 2005 to vyzerá takto
Measured value block 01:
1. Battery voltage (in V)
2. Terminal 15 (off/on/invalid)
3. Temperature (in °C)
4. -
Measured value block 02:
1. MOST address
2. ID for diagnostic information
3. Optical lowering (0 / 3 dB)
4. Temperature of MOST send diode (in °C)
Measured value block 03:
1. HW instance (designation of same control units in loop)
2. Status of loop break diagnosis wire
3. -
4. -
Measured value block 04:
1. Road speed signal
2. Vehicle speed in km/h
3. Direction of travel (forward/reverse/invalid)
K Note: At standstill, i.e. whenever the validity bit is not set, "invalid" is displayed; no storage of old direction.
4. -
Measured value block 05:
1. Rec. satellites
2. Received and used satellites
3. GPS Ant.
4. Status of GPS aerial remote feed (OK/short/open circuit)
Measured value block 06:
1. GPS FIX
2. Information
0 = GPS info not available (cold-start required)
1 = GPS info not available (Almanac, last position, time available)
2 = NO FIX: Satellites received, but no position fixing possible
3 = 2D FIX: Satellites received, 2-dimensional position fixing
4 = 3D FIX: Satellites received, 3-dimensional position fixing
255 = GPS aerial not connected
3. -
4. -
Measured value block 07:
1. Status DVD
2. Information
0 = No DVD/CD in drive
1 = Wrong DVD/CD, i.e. no navigation DVD inserted
2 = Navigation DVD inserted, read error
3 = Navigation DVD inserted and OK
4 = Load/Eject error (limit switch not detected)
5 = DVD drive error (drive cannot be initialised)
6 = DVD drive overheating
7 = Unknown error
3. DVD/CD eject button
4. Status of DVD/CD eject button (pressed/not pressed)
Measured value block 08:
1. Label of inserted navigation DVD
2. -
3. -
4. -
Measured value block 09:
1. Gyro raw value (at rest: mostly 4112; if navigation rotates clockwise the values increase; anti-clockwise: decrease)
2. -
3. -
4. -
Measured value block 10:
1. Longitude; current position
2. Degrees (-180 to 180)
3. Minutes (00 to 59)
4. Seconds (00 to 59)
Measured value block 11:
1. Latitude; current position
2. Degrees (-90 to 90)
Measured value block 12:
1. Altitude; current position
2. Altitude in m (-500m to 8000m)
3. Direction
4. Bearing (in degrees, 0=North, 90=East, 180=South, 270=West)
Measured value block 13:
1. Longitude; last stored position
Measured value block 14:
1. Latitude; last stored position
Measured value block 15:
1. Altitude; last stored position
3. Direction
Measured value block 16:
1. GPS date
2. Day (0 to 31) / Invalid (115)
3. Month (1 to 12)
4. Year (2000 to 9999)
Measured value block 17:
1. GPS time
2. Hours (0 to 23) / Invalid (115)
3. Minutes (0 to 59)
4. Seconds (0 to 59)
Measured value block 18:
1. DOP (Dilution of Precision) Quality of satellite constellation (the lower the value the better the quality)
2. HDOP Horizontal quality, 2 coordinates (0 to 9.9)
3. VDOP Vertical quality, 1 coordinate (altitude only) (0 to 9.9)
4. PDOP Overall quality of position, 3 coordinates (0 to 9.9)
Measured value block 19:
1. Front axle travel pulses
2. Status, no readout means: Travel pulse counter - no overflow
Travel pulse error status - OK
Direction - forward
Lateral acceleration sender - default applicable
3. -
4. -
Measured value block 71:
1. Satellite ID with best reception
2. Signal strength
3. -
4. -
Measured value block 80:
1. Control unit identification: MOW dd.mm.yy
Manufacturer works number and identifier
Date of manufacture
Manufacturer modification status number
Manufacturer test status no.
Manufacturer serial no.
2. -
3. -
4. -
Measured value block 81:
1. Control unit serial number
2. -
3. -
4. -
No a náväzne je nutná asi kalibrácia alebo nejaká adaptácia
4. -
1. MOST address
3. -
4. -
4. -
1. Rec. satellites
3. GPS Ant.
1. GPS FIX
2. Information
3. -
4. -
1. Status DVD
2. Information
7 = Unknown error
2. -
3. -
4. -
2. -
3. -
4. -
3. Direction
3. Direction
1. GPS date
3. Month (1 to 12)
1. GPS time
Direction - forward
3. -
4. -
2. Signal strength
3. -
4. -
Date of manufacture
2. -
3. -
4. -
2. -
3. -
4. -
