SAAB 9-5 Aero Wagon 2.3T
- Dátum registrácie: 16.05.2011 10:39 Zdieľať na Facebook
Zdravím vás potrebujem poradiť ohladom kontrolky. Niekedy keď jazdím rozsvieti sa mi taká kostrbatá kontrolka s výkričníkom (niečo ako slnko a vnutri výkričník) auto sa niekedy má problém rozbehnúť má to s tým niečo spoločné alebo ak nie čo znamená tá kontrolka.? Nikde to nemôžem nájsť. Vopred vďak za odpoveďe.
chyba automatickej prevodovky.
Tu mas manual:
http://www.saabinfo.net/index.php?Itemi ... &task=view
Automatic transmission,
fault indicator
On a car with an automatic transmission,
this warning symbol is illuminated if a fault
has been detected in the transmission.
Switch the ignition off and on again to check
if the fault persists.
Even if the fault persists, it is still possible in
most cases to drive the car (see page 159).
Have the automatic transmission checked
by an authorized Saab dealer as soon as
possible.
If the control module has actuated the
Limp-home function for the automatic
transmission, the car will remain in 5th
gear when D is selected, making it very
sluggish. To overcome this, select position
L to prevent unnecessary wear on the
transmission. The transmission then
starts in 2nd gear. When the car is moving
you can select position D,3 or 4.
When the indicator light is on, the car
must not be driven with a trailer attached.
Tu mas manual:
fault indicator
possible.
