Mazda 3 BK Chyb.Kody
- Dátum registrácie: 20.01.2019 14:38 Zdieľať na Facebook
Zdravim pani ,
P0661 mi napisalo z diagnostiky že:
nizka hodnota riadiaceho obvodu ventilu ladenia sacieho potrubia
https://www.autodielyonline24.sk/metzger-7638723.html
toto vraj zistili podla mojho vinka a danej chyby , o co sa teda jedna v com je problem auta ?
C1288-e0
hydraulicky snimac ABS/ESP , mam nahradnu sučiastku da sa to jednoducho vymeniť alebo nastane problem s riadiacou jednotkou ?
Za všetky odpovede dakujem
C1288-e0
Google vyhodil toto tu :
https://www.sinspeed.co.uk/abs-pump-esp ... witch-fail
DSC indicator light showing, diagnostics says C1288 brake pressure on demand sensor circuit Dte failure
Share this conversation
Answered in 27 minutes by:10/2/2012
Mazda Mechanic: Greg
Name is XXXXX XXXXX i will assist you the best i can, please Only accept if you are happy with my answer.
Mazda 3 ABS Pump Module fault
Fault code: “C1288 PRESSURE TRANSDUCER MAIN/PRIMARY CIRCUIT FAILURE”
This ABS Pump Module is a very common failure for the Mazda 3 built between 2004 - 2009. The fault causes the ESP light to illuminate permanently on the instrument cluster.
If you have been for a diagnostic check on your Mazda 3 then your mechanic will probably have told you that your have a fault with your “Brake Pressure sensor” or given you the full fault code of: “C1288 PRESSURE TRANSDUCER MAIN/PRIMARY CIRCUIT FAILURE” and will probably have told you that you must change your ABS Pump Module for a small fortune
What i suggest you do is try another Pump from your local salvage yard or see if you can pick one up from E-bay.
As i said this is a very common failure that i have come across so many times .
Need further assistance then please get back to me even after accepting my answer.
this is what it looks like .
graphic
Kind regards Greg
Takze treba vymenit ABS -pump za iny funkcny kus, aj ked na vine je senzor tlaku v tej pumpe...
graphic
Kind regards Greg
